zerouali med
- Joined
- Sep 2, 2025
- Messages
- 2
- Reaction score
- 2
- Points
- 3
Hi all,
I’m having an issue with my 2018 Infiniti QX50 (3.0L diesel, not VC-Turbo, 7-speed auto). The car has lost speed on highways, and the transmission won’t shift into 4th, 5th, or 6th gears. In DS mode, I can manually shift to 1st, but it won’t go to 2nd or 3rd. The diagnostic scan shows a P0720 code (output speed sensor circuit). I replaced the output speed sensor with a new one baught from nissan canada , but the problem persists—no change in symptoms, and the same P0720 code still appears.
Has anyone dealt with this on a QX50/QX70 diesel or similar Infiniti/Nissan model? I suspect it could be a wiring issue, valve body, or TCM problem based on some research. The fluid looks okay but hasn’t been changed recently. Any advice on next steps, like checking the wiring harness, testing the sensor circuit, or whether this is likely a valve body failure? I’m based in Morocco, where there are no Infiniti dealerships, and local Nissan service centers have refused to assist with my issue. I’ve run diagnostics, but i have some fear that its not sure. Does anyone know of a reliable professional online diagnostic service that can help me troubleshoot this problem remotely? I’m looking for experts familiar with Infiniti/Nissan vehicles to guide me through advanced checks or interpret scan data effectively.
Thanks for any insights!
