2013 QX56 No Crank No Start
Luzster
Evening.
Have a brand new battery, have disconnected the IPDM connector from the negative battery cable, replaced brake switch. Want to replace the push start ignition switch. Plan on replacing as much of the small stuff as I can before diving into the starter replacement.
Anyone have a good video or pictorial on how to remove the trim pieces as well as the ignition switch itself? Trying not to break tabs and ruin the panels.
If this doesn't fix the issue, I'm moving on to the relays next.
Any help?
Should add, no codes thrown ever.
