2012 QX Daylight Savings Time
Punisher
Chicago Suburbs
I have daylight savings time checked but it never changed. I turned it off and it changed, what gives? Isn't the daylight savings time supposed to set the clock automatically or does it require you to turn it on and off for the 1 hour difference?
you have to manually turn it off and on. this is the same across the armada and probably many other nissan products. i had two armadas and had to manually untick the DST setting.
i dont have that on in the car since the analog clock is there so I dont worry about it.
i know what your gonna say punish... "!@^$ an 80K car and the $#@#$%% thing wont change its time.." :p
It's like you're reading my mind. :D
yup.. i thought the same thing about the DST feature... its like my home thermostat... there's a button there for Daylight Savings Time, which either adds or subtracts 1hr from the current time... that way you don't have to manually reset the clock up/down. It's basically a 1hr clock cheat!
