My 2012 Infiniti has way too much oil on the dipstick and the oil maintenance light is on. I did the oil change and did not overfill.
Anyone else have this happen?
Either coolant or fuel in your oil will make the volume increase. "Way too much oil" sounds like a gasket failure allowing coolant to mix with your oil. Does the oil smell like gas? Is it milky or have a frothy buildup on the underside of the filler cap?
