2011 Qx56 rear is lower than front
Shauno
Why is my rear lower than front? Any suggestions?
air bags are shot
ride height sensor is not working
faulty hoses
faulty compressor
faulty relay
extra weight in the back.. :p
where is your source for this information?
a one way scantool can't correct anything - those only read off codes.
My 2011 was sagging. I replaced the compressor myself, which cost $250, only to find out it was the ride height sensor, which cost $140. I did the work myself, so I save about $1,000 the dealer wanted to charge. My mechanic can use his computer to set the ride height to factory settings, but I adjusted the sensor until it looked and felt good.
After you start the truck, do you hear the compressor turn on after 30 seconds?
