2011 QX56 lift gate does not open or close.
2011 QX56 with 47k does not respond. Open or close. The front button switch by center wheel is set to ON. Try to open with key fob, front button and rear lift gate and it does not respond at all. Anyone have the same problem or solution? Thank you.
First and foremost ... Go to the manual and ascertain if the fuse is blown. Usually some other accessory is not working as fuses usually control several items. So, check for a blown fuse....
Airlaird
Cant really pin point where the rear lift gate fuse is located. Haven't found any damaged fuses. There aren't any problems with any other parts or items in the vehicle.
On this sunny day the liftgate works today. It's acting bipolar. I am taking it to Infiniti. It's still under warranty.
@011 qx56 liftgate
Did you ever find out what the problem was because mines is not working and i can not locate the fuse?
