Jim Lansford
- Joined
- Sep 29, 2020
- Messages
- 12
- Reaction score
- 3
- Points
- 3
Recent purchase of 2010 QX56. Bought from a local business. Tried using the cruise control. Pushed the on/off button and the corresponding light came on. Then tried to use the set function. Nothing happened,no corresponding message, didn't set the speed. Tried turning the on/off button off and then back on and then the set function. The seller said he would get it fixed. He reported that a brake light needed to be replaced. I picked the vehicle up after the brake light was replaced and tested the cruise control on the way home. It worked. Several hours later I drove the vehicle again and the cruise control function would not work. Same thing with the on/off button registering and not the set function. Seller is a good guy and he says he will get it fixed. I believe him when he said he was able to use the set function several times before I picked it up. Any ideas as to what is going on that I could pass on to the seller??
