2007 Infiniti QX56 Steering Wheel Vibration
Status
Not open for further replies.
Johnphil936
Alabama
Tires have been balanced, steering wheel vibrates around 75 mph. Does not happen at lower speeds. What should I look for to remedy this issue?
Normal alignment; never heard of road force alignment.
Had the vehicle for almost 2 years, normally stay below 75 to prevent this issue. Tires are the same ones that were on it when I bought it.
Vehicle may have original struts, will get this checked out. Odometer reads 118,000 miles.
Nothing bent that I know of and haven't hit anything. Front end has been aligned in the last 6 months.
lots of people dont know about road force. does the car sit for long periods? sometimes if a car sits, the tires can get flat spots on them from sitting. this can cause some vibrations when driving a higher speeds.
since the tires were on the car when you got them, its possible they may have some flat spots on them or some other issue relating to the tires.
It does sit 3-4 days per week when I work from home. Will get the tires checked and go from there.
Status
