1999 infiniti I30 antenna problem?
bgoharriz
I need some help with this problem...when i turn the radio on..the motor turns on and tries to let the antenna come out....but its stuck an it makes a bad noise....so i just want to take the power away from the motor....is there a fuse or something that like a plug that i need to take out?
please help me!
There is a plug on the power antenna you can unplug - BTW, the same power antenna motor and electronics is on the 95-97 Altimas - you can swap the part across.
