I have an 07 m35x my nav screen freeze then goes out, radio stops working, heat/ac stuck at last settings. Happens 5 to 10 minutes after I get in the car in the morning and the screen does not come on at all at lunch time. temperature controls stuck at last settings (cant change them) radio goes in and out. per the dealership screen issue. I had that switched out same issue. I researched and saw that it is the "control module" but how do I know for sure? I also saw that a bulletin number itb07-038a that came out about "center display screen image frozen" "IF YOU CONFIRM The image on the center display screen (front display unit) will not change (is frozen) when operating the radio,
A/C, and/or navigation system controls" this is similar to the problem I am having but not exactly. When I spoke to the mechanic about the on going issue and what I found in my research I asked him if it could be the controller vs the control module. he said control module. How do I confirm what each of those devices does?
online it says the replacement part for control module is part number 25915-EJ37B for the 07 m35x infiniti. does the part 25915-EJ36C also be a replacement part?
