Will QX80 headlights fit my 2012 QX56?
56er
Nashville
I was wondering if the QX80 headlights would be a direct fit to my 2012 QX56. I like the daytime running LEDs in the new QX 80 headlights.
....Or, if anyone manufactured headlights for my QX56 that had daytime LED lights incorporated within.
Thanks in advance.
jrm5f2
82
2
8
Hey everyone! After looking at this closely it looks like this could be a direct fit. The reason why I say that, is because there is a user on here that as already done the conversion from QX56 front to QX80 front without changing his headlights. If the above statement holds true then his conversion shouldn't have worked. I could be wrong, but after looking at it closely I believe I am right. Also it looks like the plug is also a match. I am planning on do this sometime in the future myself. Just my two cents.
Here is the truck I am talking about.
Ducebiggie30
Thanks in advance.
Did you find out if the headlights fit without changing bumper grille etc.?
So can the headlights be swapped out without changing bumper grille etc. ?
G
G-614067
Hey I would have to look again it's been so long since I looked into this, but what I can remember is that yes the headlight is a direct fit physically. The issue is wiring, fuse, IPDM, and the BCM. It's not hard to do just require some know how and maybe some splicing to get the LED DRL's to work how you want them. Somewhere on this forum I explain this already in detail, I just need to find it. Since they changed the layout it will probably take me a second.
jrm5f2
82
2
8
Hey I would have to look again it's been so long since I looked into this, but what I can remember is that yes the headlight is a direct fit physically. The issue is wiring, fuse, IPDM, and the BCM (CAN). It's not hard to do just require some know how and maybe some splicing to get the LED DRL's to work how you want them. Somewhere on this forum I explain this already in detail, I just need to find it. Since they changed the layout it will probably take me a second.
Ducebiggie30
Ok so u saying the lights would mount up and fit the 2012 bumper and grille? And yes i do understand having to do some splicing and wiring matching leads i had to do something very similar to my 10-13 Camaro when i installed 14-15 headlights front bumper and grille i had to do splicing and wiring to match up for headlights and turn signals
Isaac911
3
3
Hi jrm5f2
the only concern I have preventing me from upgrading the headlights to 2015 is:
AFS(Adaptive Front-lighting System)
is the AFS working normally after upgrading the headlights to 2015?
if there is any error showing on the dashboard regarding the AFS?
Please respond
jrm5f2
82
2
8
Hi jrm5f2
Please respond
Let me look into this I don't think it should be a problem but let me check the service manual.
Look at the pictures I have attached, the mother that controls the as is the same on both, so really this should be plug and play. Again let me look at the service manual to verify
Isaac911
3
3
YES maybe it is plug and play
but it doesn't mean the AFS(Adaptive Front-lighting System) will work normally after upgrading the headlights to 2015
waiting for you to verify
thank you
jrm5f2
82
2
8
thank you
Verified, you can not upgrade without splicing some wires to get the AFS to work and trail/ error. Although they have the same plug, the wires are different, refer to the pictures from the service manual. One is taken from a 2011 and the other from a 2015 with the new headlight system. I am not saying you can't get it to work, but it will take getting into the weeds. SmartSelect_20190926-212958_Dropbox.jpg SmartSelect_20190926-212301_Dropbox.jpg
