Sid3ways
- 2
- 3
I’m running into a slightly similar issue on my 2012 QX56 with the air/hydraulic shocks. After a tire change at the shop, I’ve noticed the rear end of the suv is now squatting. Started to do some searching online and it seems a lot of issues are from the lines and fittings but don’t speak about the hydraulic shocks, do those suffer the same issue?
Anyways, initially I don’t hear the pump coming on when I start the vehicle. So we hooked 12V up directly to the pump and the pump fires up. Seeing as though the pump functions we then took the level sensor arm off, and pushed it up (with ignition on and also engine running) and never had the pump kick on. The vehicle was still on the hoist so the front tires weren’t on the ground (don’t know if it knows somethings up if front has no load and the rear shows a load so it doesn’t trigger the pump?).
At that point we just manually triggered the pump to run by hooking up directly (without vehicle harness connected) and it eventually pumped the rear up to regular ride height and we heard it click and it shut off on its own (is there a pressure switch?). I drove it home from my friends shop which is about 5 miles away and it had settled back down by the time I got home so I assume there’s a leak too. Is it possible the system thinks it’s constantly too high so it tells it to bleed off air when it shouldn’t?
I see there are a few relays according to a manual I saw but I could only find one relay to test and the relay was fine. I couldn’t find the fuse, which fuse is it?
Thank You for any help you can provide!
