Infiniti I35 Stripped bolt, need help
DaltonSmith
Hi, I have an i35 that I bought that just needs an alternator and a belt, but after I got the ac compressor off, I realized someone tried to work on it and stripped the nut for the tensioner that sits above the alternator aand stripped the lower alternator bolt. Could I just use a grinder to cut the nut off and just cut the bolt off and replace it?
