How do I check the AC fuse on 2001 Infiniti QX4?
John N
Today i put my AC on Econ for a while. When I switched back to Auto, the fan no longer worked. I cannot get it to blow any air. I would like to check the fuse. I found it, but can't get it out. The manual says to use the "fuse puller", but unfortunately, it does not say where it is or what it looks like. I can't find one, and assume I don't have one.
Is there a chance it is in fact just a blown fuse?
If so, how do I get the fuse out, and how do I confirm whether it's blown?
If it's not just a fuse, I assume I need to take it to the dealer. However, they also service our Lexus, and between the 2 cars, I rarely get out of there without spending $500-1000.
Thanks very much in advance.
John
G
G-510969
Fuse puller is small white plastic square in bottom right of interior fuse panel. You can also use needle nose plyers or tweezers if the oem puller is missing.
