G20 steers hard right when Accelerating
Charlieh88
G20 was steering right when accelerating: found gusset pin which is attached by 3 bolts Torque approx 100 FT Lbs to Subframe, Found all 3 bolts loose, On one of the 3 nutplates its loose in subframe. Has anyone fixed this i problem with heliicoils or would you recommend any other repairs? This is a 2001 G20 with 105 K on engine 150 K on Body . The Gusset pin also attaches to lower traverse link
