Engine Swap!!
TheGagiantor
I have a 1995 Infiniti G20 with the sr20de and standard trans. i see on the head the identication " 94Y" . Long story short, the bottom end it bad so i bought a new engine from a 1999 automatic Sentra i THINK. Identification on the head is "2J2" and is from Japan with no EGR. I already noticed ALOT of differences in the intake and exhaust manifolds, valve cover ect. so i already pulled my engine and started swapping the parts over. Any thing i need to know? i swapped my distributor over because mine has 2 plugs and the one on the new engine has one... dont know what problems i might run into so thought id ask!!
thanks
