2011 QX 56. Around 120k on miles. Got a issue with “supposedly” my ECM. A P062B code came up, after I had to have a BCM flash for a rear suspension compressor that I put on. Apparently the car didn’t recognize. After I pulled away from the dealer is when all hell broke loose. The car would die out at stop lights. Finally a SES light popped up giving me something to chase down. Well darn, had to be the ECM. What a coincidence.
Off to the dealership! FUn fact: I hate the dealerships. Overpriced and they just swap parts. Turns out the wiring harness is bad too! $5,500 dollars later my car is ready to be picked up. Swapped out ECM engine harness, new ECM and new ECM relay. I asked for all the parts back. As should you if you have to deal with the dealership. Just to ensure the work was done. They are having a hard time locating my ECM they removed. Yet another coincidence.
Has anyone else had the luck that I have had with the QX56?
