Bought the vehicle used with about 165,000 on it. Fellow I bought it from buys cars from dealerships. So, no history. I was told that the car had been being used as the family vehicle prior to me purchasing it.
The seller is a good guy. He has taken on fixing the airconditioning(replaced the radiator) and a problem with the hatch window latch. He has said he would take care of the cruise control issue as well. His mechanic installed the switch that is actuated by the brake pedal. That was the first step. The cruise control worked at least once after that switch was replaced and then quit. His mechanic could not get it working again, I think he replaced the cruise control module(if there is one) and when that didn't work they took it to the local Nissan dealership where it has been for 2 1/2 weeks. The story I heard is that they called in a specialist after they couldn't get the cruise control working and declared it needed another module(possibly an ABS module?). The seller purchased such module, used, 2 different times now, and each time the report from the service guy at Nissan said they couldn't get it programmed. Both units had been tested prior to being shipped(so we are told) and found to be working.
The Nissan service rep keeps saying that the car needs a new module that costs $2,500, in order to work.
I just spoke to the seller who told me he ordered a new module that is supposed to arrive Monday. He is frustrated of course and I am too. The seller has loaned me a vehicle to drive the entire time my car has been at the Nissan dealership.
I thank you for your reply. I had conversations with you before about this vehicle, probably two months ago. You have been very thorough and prompt.
To answer another part of your reply, no, no error lamps come on when I try to set cruise, it simply does not go into cruise and the light that would indicate that it is in cruise mode does not come on. The light that indicates the button to start that sequence does come on, but that is all.
