A/C Condesor fan and Compressor
mtimothy3
I have had my 91 M30'S A/C Converted to 134a. The system will not engage with the A/C button in the car, however, when I jump the compressor and or condenser fan it works perfectly. I have replaced all relays and fuses. The fusible links look good.
What should I check next? Inside switch? ground?
Thank you for your suggestions and insight
