2013 G37 Won't turn off
JeffB
RE: 2013 G37 / 62K Miles
Recently had water leak on passenger side floorboard. Had mechanic clean the sun roof drain and leak has gone away. Now the car is acting crazy. It won't turn off, almost every indicator light goes on and off. The vehicle is possessed by a demon. The engine finally turned off and I immediately disconnected the negative battery terminal and the car went to sleep. I went on line and found a couple of references to sun roof water leaks causing problems with computer modules. The module may be water damaged. Does this sound logical ? Thanks for your help. Jeff
