2012 FX50 Fault Code 0011
Ochologan2000
Hopefully someone can help with Hopefully someone can help with What appears to be a timing issue with my 2012 FX50. When I start the caWhat appears to be a timing issue with my 2012 FX50. It seems to start just fine and idols perfectly but anytime I hold the throttle, the engine revved up and down sporadically and eventually will die if I give it to much throttle. I have tried replacing the mass airflow sensors, camshaft timing solenoid’s, and camshaft timing sensors. Fault code that I’ve been able to pull is 0011. I have a video as well that I will try to post.
