2007 G35x rt front drive shaft replacement
BadDad
Kennewick
I have a broken shaft at the u-joint. Advice on removing the shaft without disconnecting the transfer case or removing the rear drive shaft? There doesn't appear to be much play. I don't want to stay putting things apart without proper advice.
