Brake lights were staying on so I check the rubber piece on the brake pedal it was ok but I replaced anyway still lights on .So we determined it was indeed the switch itself . So I went and brought a beck anley replacement switch, but the problem was the switch does not fit the plug from the wire harness. So I went an ordered one from Infiniti itself and it"s the same configuration as the beck anley switch just more expensive. I look at all the replacement models and they are the same so I am wondering what can I do now. The switch that came out of the car I am assuming it is the original because it fits the connector from the wiring. The new switch from the dealer installs just like the original except the prong alignment are different and does not connect to the harness. Any suggestions from anyone
