Go Back   Infiniti Forum > Infiniti Forums (Infiniti SUVs) > Infiniti Full-Size SUV Forums > Infiniti QX80 Forum
Infiniti Forum: Can powerlift max height be adjusted. 2018 QX80
Old 01-20-2019, 07:29 PM
D2isback D2isback is offline
Default Can powerlift max height be adjusted. 2018 QX80
Can the max height on the Qx80? The door now hits the top of my garage door, so I need to lower the max height about an inch.
Old 01-21-2019, 08:11 AM
SUPER MODERATOR
Do you mean the rear hatch? It can't be adjusted from my understanding.
Old 01-21-2019, 11:52 AM
Quote:
Yes the rear hatch. I didnít see anything about the max height being adjusted in the owners manual so thatís what I figured. Very unfortunate. Thanks
Old 01-22-2019, 01:25 AM
Kcrebel Kcrebel is offline
It can't but I will tell you how I worked around the same issue. Instead of remotely opening or powering open the hatch I manually opened it and assisted it to the height I needed it to stop. It doesn't technically stop the travel but it takes the pressure off the hatch as it rests against the garage. If you need it to be open for longer periods of time and will be loading/unloading significant weight that may cause the suv to move you can always add a towel or two between the door and hatch to provide some extra cushion. I had a 12 and a 15 in the same garage that I worked out of so I was always loading stuff into the hatch at home along with groceries, gear, etc and never damaged either one with my "altered method".
Hope that helps.
