Go Back   Infiniti Forum > Infiniti Forums (Infiniti Cars) > Infiniti I30 / I35 Forum
Notices
Infiniti Forum: Rear view mirror gets loose
Old 05-02-2018, 11:38 AM
mountie mountie is offline
Default Rear view mirror gets loose
In the heat, the rear view mirror gets loose. How do you fix it?
You Tube has no videos.....
I assume the Forum administrator will ignore this thread as usual.
Click image for larger version
ID:	690   Click image for larger version
Old 05-06-2018, 05:49 PM
So, NOBODY has had the problem? Hmmm.....
A few have looked at the post, but....
( Do the administrators peek at these posts & keep silent? )
Old 07-02-2018, 08:24 AM
atty atty is offline
Well, apparently the I30 section is not too active.
I just inherited a '98 yesterday, so I will be doing a lot of "finding out" in the next few months. I know that doesn't answer your question, but I did see a post indicating that the I30 is highly similar to the Maxima mechanically. Perhaps someone in those forums have stumbled across the same problem.
Good luck with your research and post your findings. Need to knock the cobwebs off of this section.
