Go Back   Infiniti Forum > Infiniti Forums (Infiniti Cars) > Infiniti Q70 and M Forums > Infiniti Q70 Forum
Infiniti Forum: Engine air filter Q70
Old 03-25-2018, 05:11 PM
bbqbrisket bbqbrisket is offline
Default Engine air filter Q70
In researching prices on engine air cleaners/filters, I see several sites says change requires 2 filters.
I know one is located up front just back of the radiator on the drivers side; a very very easy change out.
I'm puzzled where the second one would be if it's true it needs 2.
Can someone advise.
thanks
Old 10-12-2018, 03:07 PM
MadMatt17 MadMatt17 is offline
No one likes to answer questions around here.
There is two on the 3.7 anyway. If you found one, look in the same spot on the other side of the engine.
Aftermarket is very limited for filters. I've pretty much only found K&N replacement filters and not CAI.
Old 11-02-2018, 07:49 PM
Chany3426 Chany3426 is offline
Yes, you need two of them, change them is a relatively operation, a 1 minute job.
There are two intake runners one is at the front right of the engine bay, the other at left, you won't miss it.
Hope this helps
infinitiforum.net recognizes that "Infiniti", "Nissan", it's logos and various model names and numbers are registered trademarks of Nissan Motor Co. Ltd.. These terms are used for identification purposes only. infinitiforum.net is not affiliated in any way with Nissan Motor Co. Ltd. or any other company listed herein. All information on this site is the opinion of its members and not the opinion of the site itself. ©2019 Madison Ross Media Group. All rights reserved. Content published on InfinitiForum.net requires permission for reprint. Interested in an affordable, reliable luxury SUV? Check out the Kia Telluride.
