Notices
Infiniti Forum: 2015 QX80 P0307 Code
  #1
Old 03-22-2017, 07:35 PM
courtright11 courtright11 is offline
Default 2015 QX80 P0307 Code
Just bought a used QX80 with 26K miles, 3 days after we got it, the engine light came one. Brought it back to the dealer - Code P0307 came up (misfire). They replaced two injectors - didn't work. They just replaced the ECM today - didn't work (I was told Cylinder compression is good).
ANY THOUGHTS????
  #2
Old 03-27-2017, 09:25 PM
0macman0 0macman0 is offline
Thought is you are totally under warranty! Keep taking it back. Random misfire or just a certain cylinder?
  #3
Old 03-31-2017, 07:31 PM
Cylinder 7 - I was told it was the GAS. The engine light is out, but it still seems to rev a bit. Not sure if something is off or I need to get used to the way it drives?
  #4
Old 04-01-2017, 02:24 PM
Kcrebel Kcrebel is offline
Senior Member
What gas are you using in it?
  #5
Old 04-02-2017, 08:21 PM
Not sure, the dealer had filled it up - using 93 (prem) now.
  #6
Old 04-04-2017, 07:04 PM
I have a hard time believing that it was the gas causing a misfire, but if it doesn't come back, awesome.
  #7
Old 04-05-2017, 09:10 AM
Me too - and it came back on today. This time, it's P2097 Post Catalytic Fuel Trim System Too Rich Bank 1
They are picking it up today and taking it for service.
  #8
Old 04-09-2017, 07:05 PM
Sounds like you may have an ignition problem, bad plug or coil pack, or maybe your upstream sensor is reading incorrectly. Be aware there is a good chance this could cause your catalytic converter to fail prematurely.
  #9
Old 04-10-2017, 07:37 PM
Thank you for the feedback - I was told they replaced an sensor, I am guessing O2 - they said the light is off and it is running good. They are going to keep a couple more days to to ensure it's fixed.
  #10
Old 05-05-2017, 07:33 PM
Light came back on (two codes, P0300 & P0307) - I took it to a different dealership, they replaced all 8 Injectors and Spark Plugs. Was told it was running better, but there is a combustion problem. After a week and 1/2, they said the issue is with one of the Cylinder Heads (deemed a defect), they replaced both. I was told today, that it is running 100%, picking it up tomorrow.
Copyright ©2000 - 2018, vBulletin Solutions Inc.
