Go Back   Infiniti Forum > Infiniti Forums (Infiniti SUVs) > Infiniti Full-Size SUV Forums > Infiniti QX56 Forum
Infiniti Forum: Differential Seal Leak
Old 01-11-2019, 07:55 PM
ChesbayQX56 ChesbayQX56 is offline
Default Axle popped out of Front Differential
2013 QX56 front passenger side axle has popped out of the differential about 1/2 to 3/4 inch. I assume the clip needs to be replaced along with the seal and just pop it back in. Has anyone had this issue?
Click image for larger version
ID:	728   Click image for larger version
Old 01-12-2019, 12:25 PM
SUPER MODERATOR
you can obtain the FSM online for free and read up on the procedure. you can also call into a local infiniti shop and ask them.
Old 01-14-2019, 09:54 AM
I put the truck on the lift yesterday and the axle has not popped out of the differential but is leaking from the seal. I am going to add fluid and monitor the leak. A seal replacement is probably in the near future.
Old 04-02-2019, 01:34 PM
shawn19 shawn19 is offline
I have a 05 that the driver side pop out and now i have to replace the differential not happy.
Tags
differential seal, front final drive
