Go Back   Infiniti Forum > Infiniti Forums (Infiniti Cars) > Infiniti Q40, Q50, Q60 and G Forums > Infiniti G25 / G35 / G37 Coupe and Sedan Forum
Infiniti Forum: 2007 G35x rt front drive shaft replacement
Old 04-06-2018, 07:25 PM
BadDad BadDad is offline
Default 2007 G35x rt front drive shaft replacement
I have a broken shaft at the u-joint. Advice on removing the shaft without disconnecting the transfer case or removing the rear drive shaft? There doesn't appear to be much play. I don't want to stay putting things apart without proper advice.
Old 05-30-2018, 08:54 AM
Nemitz Nemitz is offline
I'm curious if you did anything to fix this, BadDad? I'd love to know if you got some advice elsewhere.
