Infiniti Forum: 2012 QX56 - P062B code - Sputtering and loss of power
  #11
Old 07-18-2018, 03:40 PM
pjdavep pjdavep is offline
Quote:
Originally Posted by rbmphillips View Post
Cleaned the battery, cleaned the ECM conncetions, SES light come back on yesterday. Loss of power going up hills. What kind of symptoms does a bad catalytic converter give?
Cleaned battery, but didn't change it out for a new one? I doubt that's it at this point, unless it's somehow freaking out the computer (that's tech talk). I've had batteries going bad that made a watch run faster instead of slowing/stopping.
Bad cats would give bad gas mileage, and I'm sure the cat related codes would be thrown.
Later,
pjdavep
  #12
Old 07-20-2018, 09:05 AM
rbmphillips rbmphillips is offline
The battery tested good and passed the battery load test.
The vehicle is at the dealership now. Im getting a 2nd opinion about it all. Hard for me to believe that both harnesses and the ECM are all bad.
  #13
Old 07-20-2018, 10:28 AM
ChesbayQX56 ChesbayQX56 is offline
I had a similar problem with my 2013 QX56. I was getting some crazy ECM codes because the volts were low. The battery checked out Ok so I started to monitor the volts with the gauge and a live/bluetooth OBDII app. The alternator was constantly turning off and never fully charging my battery. The dealer acknowledge the problem and did something with the idle that helped a little.
Ultimately, I leave the headlights on which always keeps my volts at 13.7. I would recommend that you look at the volts gauge when it starts and then after 3-4 minutes of driving. If the volts drop way down, trying turning on the headlights.
  #14
Old 10-11-2018, 07:19 AM
So your qx56 was sputtering and losing power due to low voltage? I think our daytime running lights are always on when we drive but I will double check that. Did you mean day time running lights or regular night time head lights?
Thank you for your input. I have had little luck trying to fins anyone that has had my same problem.
Replaced the ECM & EGI Wiring Harness. $3500.00 and the problem has not returned. Also had the catalytic converter location modified. We cleaned out the insides of the original cat and welded in a new cat down the exhaust a little bit so that in the future we would not have to replace the entire exhaust manifold because of cat issues. Relocated both sensors as well.
  #15
Old 10-16-2018, 12:19 AM
Keketd Keketd is offline
Default Cost of Repair?
I'm having the exact problem and I replaced my ECU and the code P062B came back again. Do you happen to know what part number it was that you replaced and the cost of the repair?
  #16
Old 10-17-2018, 09:04 AM
jstark jstark is offline
Also had the catalytic converter location modified. We cleaned out the insides of the original cat and welded in a new cat down the exhaust a little bit so that in the future we would not have to replace the entire exhaust manifold because of cat issues. Relocated both sensors as well.[/QUOTE]
Hey RBM, can you disclose specifics, like parts used and/or snap a pic or two of the Catalytic converter modification?
Thanks!
  #17
Old 12-21-2018, 01:22 PM
Quote:
We replaced the ECM AND EGI Wiring harness.
Thanks![/QUOTE]
I will upload pics today.
Did you get yours fixed. My problem returned last night. We replaced ECM and EGI wiring harness and now the problem is back.
  #18
Old 01-08-2019, 11:00 PM
At rbmphillips:
Here is a screen shot of the freeze frame data from my scan tool for the code P062B from my QX56.
Freeze Frame Information
Parameter Description Results
Fuel Sys 1 CL
Fuel Sys 2 CL
Calc Load 52.94 %
ECT 71.60 °F
STFT B1 25.00 %
LTFT B1 4.69 %
STFT B2 25.00 %
LTFT B2 3.13 %
MAP 12.40 inHg
Eng RPM 1212.50
Veh Speed 17.40 mph
Spark Adv 34.00 °
IAT 55.40 °F
MAF 3.44 lb/min
TPS 11.76 %
O2S B1 S2 0.29 V
STFT B1 S2 99.22 %
O2S B2 S2 0.27 V
STFT B2 S2 99.22 %
Run Time 55.00 sec
MIL Dis 0.00 miles
LAMBDA B1 S1 1.17
O2S B1 S1 1.70 V
LAMBDA B2 S1 1.42
O2S B2 S1 1.90 V
Command EVAP 0.00 %
Fuel Level 100.00 %
Warm-up DTC Clr 15.00
Clr Dist 96.31 miles
EVAP_VP 0.00 InH2O
BARO 23.33 inHg
CAT Te 11 32.00 °F
CAT Te 21 32.00 °F
ECU Volts 14.40 V
LOAD Value 38.43 %
EQ Ratio 1.00
Rel TPS 6.27 %
TPS B 11.76 %
ACC Pedal D 16.08 %
ACC Pedal E 16.86 %
Command TAC 12.16 %
MIL Time 0 hrs, 0 min
Clr Time 6 hrs, 28 min
FUEL_TYP GAS
FRP_A_CMD 2094.34 psi
FRP_A 2089.99 psi
FRT_A -40.00 °F
FRP_B_CMD 0.00 psi
FRP_B 0.00 psi
FRT_B -40.00 °F
I'm working now on trying to find if there is a short in the harness (EGI) that is causing the code as indicated on the car service manual. Hopefully I'll be able to locate that short using the power probe and I'll give an update on that if and when I get around to it.
At rbmphillips if you have replaced the ECU and EGI harness it might be one of your sensor connector harness thats causing the issue is my guess.
