Go Back   Infiniti Forum > Infiniti Forums (Infiniti SUVs) > Infiniti Compact CUV Forums > Infiniti EX35 Forum
Notices
Infiniti Forum: Infiniti EX35 Electrical Issue
Old 06-20-2017, 08:42 PM
slice235 slice235 is offline
Default Infiniti EX35 Electrical Issue
Hopefully someone can offer some guidance on an electrical issue I am experiencing with my 2008 Infiniti EX35 crossover. There seems to be an electrical short which is tripping the fuse for the driver power seat, cabin lights, and power rear view mirrors. I ride a ferry to work each day and usually move my driver power seat back and down to relax so the power seat is being used daily. After replacing the fuse the seat, lights, and mirrors operate fine for a day or two then the fuse trips again. I have disconnected all devices from the internal outlets but the fuse keeps tripping. My local mechanic is trying to find the source which may be the driver power seat, but he says he would have to rip apart the wiring harness under the seat to test which would take hours. Before we commit to this work, has anyone experienced this issue or have an idea of other things we should look at. Want to avoid taking this to the dealer as it will most likely be very costly.
Thank you in advance.
Old 08-15-2017, 11:58 AM
Jon2010EX35 Jon2010EX35 is offline
Shorts are one of the worst issues to resolve. If you are sure it happens only when the seat is moved, I would take the seat out and start rummaging through the wires that move as the seat moves. Locate the wires related to the circuits that short and then use a multimeter to test various wires as the seat moves. Failing that, I'd take it to an automotive electrical expert, not just a generalist.
Old 08-15-2017, 03:12 PM
R2urbo R2urbo is offline
Are you the original owner? Do u have aftermarket bulbs? Could be the wrong size bulb. This happened to me before when I changed the bulbs with after market.
infinitiforum.net recognizes that "Infiniti", "Nissan", it's logos and various model names and numbers are registered trademarks of Nissan Motor Co. Ltd.. These terms are used for identification purposes only. infinitiforum.net is not affiliated in any way with Nissan Motor Co. Ltd. or any other company listed herein. All information on this site is the opinion of its members and not the opinion of the site itself. ©2017 Madison Ross Media Group. All rights reserved. Content published on InfinitiForum.net requires permission for reprint.
