Go Back   Infiniti Forum > Infiniti Forums (Infiniti Cars) > Infiniti I30 / I35 Forum
Notices
Infiniti Forum: 1998 i30 has code P0325 P0440 P0400 P1448
Old 04-12-2016, 08:38 PM
lordofthering lordofthering is offline
Default 1998 i30 has code P0325 P0440 P0400 P1448
Hi,
My 1998 Infiniti i30 has P0325 P0440 P0400 P1448 codes. What should I do first ?. My inspection failed.
Explanation of codes are below:
P0325 - Knock Sensor Circuit Malfunction
P0440 - Evaporative Emission Control System Malfunction
P0400 - Exhaust Gas Recirculation Flow Malfunction
P1448 NISSAN - EVAP Canister Vent Control Valve Open
I have tried below so far:
--> Replaced Gas cap from Dealer, cleared code with scanner but all code came back.
Please help me to tackle this issue. I am not sure where to start. I think I can ignore P0325 for no. P0440, P0400, P1448 seems to be inter-related. Should I replace EVAP Canister ? OR I should replace EGR Valve ?
Old 04-14-2016, 03:14 PM
Finally i tested EGR Control Solenoid Valve and looks like it is bad. There is no click sound when I apply 12 V to green adapter positive and Negative connection.
Now I want to remove this EGRC valve and replace with new one but I am not able to figure out how to remove it. Per Image, there is one Nut under the Green adapter shown but I am not able to open Nut due to tight spot. Green Adapter has bolt which is sitting on steel plate and Nut under plate is holding bolt. Anyone can give me idea how can I open Nut under the adapter ?. I tried to use 10 mm racheting wrench with swivel but I am no having leverage to open nut. I did use WD-40 as well.
Click image for larger version
Old 06-13-2017, 01:10 AM
FredInce FredInce is offline
Oh that's not good. I have the same issue. Did you end up getting it fixed?
Old 07-15-2018, 10:37 AM
DouglassNettles DouglassNettles is offline
Quote:
What model are you driving? What problem are you exactly facing? If you can specify the details, maybe we can help.
  #5
Old 07-20-2018, 04:52 AM
Quote:
Now I want to remove this EGRC valve and replace with new one but I am not able to figure out how to remove it. Per Image, there is one Nut under the Green adapter shown but I am not able to open reviews of phen q Nut due to tight spot. Green Adapter has bolt which is sitting on steel plate and Nut under plate is holding bolt. Anyone can give me idea how can I open Nut under the adapter ?. I tried to use 10 mm racheting wrench with swivel but I am no having leverage to open nut. I did use WD-40 as well.
I ended up changing the wrench and it worked fine.
