Infiniti Forum: QX56 Won't Start
  #11
Old 10-24-2018, 06:39 PM
Senior Member
SUPER MODERATOR
Body Control Module = BCM
Transmission Control Module = TCM
both are expensive to replace. the parts may be a few hundred but I dont know. you can search online.
the BCM is the head honcho. it controls/governs many sensors and actions on the car. example, when you want to put the car in drive from Park, the BCM tells the TCM the shift selector has moved to Drive and that the TCM needs to engage the tranny to proceed with the function of driving (the ECM also plays here as its the LOGIC behind all of this) . the BCM also calls for the doors to lock and for the headlamps to engage in sensing the steering wheel )so the lamps can move when the steering wheel moves, etc) , and other functions that happen without our awareness.
the TCM is AS important as the BCM.
Tags
electrical, no crank, no start, startup problem
infinitiforum.net recognizes that "Infiniti", "Nissan", it's logos and various model names and numbers are registered trademarks of Nissan Motor Co. Ltd.. These terms are used for identification purposes only. infinitiforum.net is not affiliated in any way with Nissan Motor Co. Ltd. or any other company listed herein. All information on this site is the opinion of its members and not the opinion of the site itself. ©2019 Madison Ross Media Group. All rights reserved. Content published on InfinitiForum.net requires permission for reprint. Interested in an affordable, reliable luxury SUV? Check out the Kia Telluride.
