Infiniti Forum: 05 QX-Rear Window Phantom Unlock? Electrical Issues?
  #1
Old 09-27-2012, 07:27 AM
QX-Dex QX-Dex is offline
Default 05 QX-Rear Window Phantom Unlock? Electrical Issues?
I'm new to this board, so please excuse any re-questioning. I'm having electrical issues with my 05 QX56. My rear window locks/unlocks itself, nonstop, when the window is fully closed. I have to drive around with the window not closed and the 'Rear Window Open' message flashing on my dash. I tried removing the battery and letting it sit awhile to reset everything electrical in the truck. No luck.
Also, almost all of the warning lights on the dash are lit. The Low Tire Pressure, Airbag, Door Ajar and others are lit. However, the Odometer readings are only half lit. In other words, you can't read the numbers in the digital readout.
Finally, my fan controls will only turn my fans off or on. There is not low-to-high setting. It eaither blasts full or is off. The temperature setting work. So, I can blow hot or cold air, but only on full blast.
I really don't want to take this thing back to Inifiniti to hook it up to the computer, so any suggestions would be greatly appreciated.
Thanks,
  #2
Old 10-23-2012, 04:03 PM
dso dso is offline
As for the rear window, I had the same problem with my 07. You need to replace the rear window release switch on the tail gate. The dealership did mine under warranty and it was fixed.
Tags
air, battery, electrical, lock, power
infinitiforum.net recognizes that "Infiniti", "Nissan", it's logos and various model names and numbers are registered trademarks of Nissan Motor Co. Ltd.. These terms are used for identification purposes only. infinitiforum.net is not affiliated in any way with Nissan Motor Co. Ltd. or any other company listed herein. All information on this site is the opinion of its members and not the opinion of the site itself. ©2019 Madison Ross Media Group. All rights reserved. Content published on InfinitiForum.net requires permission for reprint. Interested in an affordable, reliable luxury SUV? Check out the Kia Telluride.
