Go Back   Infiniti Forum > Infiniti Forums (Infiniti Cars) > Infiniti Q40, Q50, Q60 and G Forums > Infiniti G25 / G35 / G37 Coupe and Sedan Forum
Notices
Infiniti Forum: New G37 owner, couple tech questions
  #1
Old 09-16-2017, 10:55 AM
lrust lrust is offline
Default New G37 owner, couple tech questions
I recently bought a 2010 G37 with 165k miles. New to this forum, I have a couple basic questions. I can do most mechanical work but I don't have much experience with this type of car.
1. Is there a repair manual or technical guide that anyone would recommend? Chilton or other?
2. I have some front end noise from front passenger side. It "feels" like a wheel bearing - not the tire itself. Any known issues? or is there a recommended change interval for ball joints, wheel bearings, etc?
3. I have some slight odor & dampness. No obvious water leaks that I can see. Any known issues prior to me tearing stuff apart to find a small leak? heater core?
Thanks in advance.
  #2
Old 09-17-2017, 05:56 PM
Infiniti Forum Infiniti Forum is offline
Administrator
Hey. Welcome! You could try this:
http://repair.chiltondiy.com/Pub/DIY...Repair&b=92771
If that doesn't help let me know...
__________________
Want to be connected with everything automotive in your area? Check out Cars Connected today!
Get your next Infiniti for the lowest price possible! Go to TrueCar.com first!
  #3
Old 11-19-2017, 02:29 AM
Lancelot Lancelot is offline
You should be able to download the 2010 G37 Factory Service Manual here:
http://www.infinitig37.com/2010-Infi...Sedan-FSM.html
  #4
Old 11-23-2017, 11:03 AM
Administrator
Thank you for the link, Lancelot!
__________________
  #5
Old 11-28-2017, 10:02 PM
ManofaG35 ManofaG35 is offline
From my experience if you had a leak from your heater core you'd likely know by a hazy film build up on your windows from the anti freeze, also every cooland I ever used has a distinct odor you'd smell, I would think, do you know if perhaps it could be the drain tube plugged for your ac, I had that happen once in my truck, sounds similar.
Copyright ©2000 - 2018, vBulletin Solutions Inc.
infinitiforum.net recognizes that "Infiniti", "Nissan", it's logos and various model names and numbers are registered trademarks of Nissan Motor Co. Ltd.. These terms are used for identification purposes only. infinitiforum.net is not affiliated in any way with Nissan Motor Co. Ltd. or any other company listed herein. All information on this site is the opinion of its members and not the opinion of the site itself. ©2017 Madison Ross Media Group. All rights reserved. Content published on InfinitiForum.net requires permission for reprint.
