Go Back   Infiniti Forum > Infiniti Forums (Infiniti Cars) > Infiniti Q40, Q50, Q60 and G Forums > Infiniti G25 / G35 / G37 Coupe and Sedan Forum
Notices
Infiniti Forum: 2008 g35x cooling fans
Old 09-18-2017, 03:35 PM
Bubbamachine Bubbamachine is offline
Default 2008 g35x cooling fans
Radiator fans work on high speed when ac is on won't run without ac on. Have voltage of 5.6 without ac on constantly to both fans with starting temp of 170f all the way to 210f. High speed voltage when ac is on at 13.9. Anyone have knowledge on the subject. I figured I would see a voltage increase as coolant temp increased.
No check engine light with codes so I sorta ruled out any sensor issues. Pwm relay snaps closed when energized and has continuity but don't know how to test more thoroughly.
infinitiforum.net recognizes that "Infiniti", "Nissan", it's logos and various model names and numbers are registered trademarks of Nissan Motor Co. Ltd.. These terms are used for identification purposes only. infinitiforum.net is not affiliated in any way with Nissan Motor Co. Ltd. or any other company listed herein. All information on this site is the opinion of its members and not the opinion of the site itself. ©2017 Madison Ross Media Group. All rights reserved. Content published on InfinitiForum.net requires permission for reprint.
