strutmasters suspension  andys auto sport
Go Back   Infiniti Forum > Infiniti Forums (Infiniti SUVs) > Infiniti QX4 Forum
Register FAQ Members List Calendar Search Today's Posts Mark Forums Read
  #1
Old 01-24-2010, 02:30 AM
linus73 linus73 is offline
Angry 1999 infinity qx4 rough idle problems
i recently purchased a 1999 qx4. i had the rear main seal, trans seal, crankshaft seal replaced due to oil leaks. i also changed all the belts and did a full tune up, including ngk spark plugs, wires, cap and rotor, pcv valve and a maf sensor. also had a cat convertor replaced and the truck still!!! idles rough and smooths out intrmittently., the other day it stalled at the light. i even tried fuel injector cleaner on 2 seperate fill ups. the truck still idels rough!!! cant figure it out, any help will be most valued.
  #2
Old 01-24-2010, 02:31 AM
p.s replace the timing belt and water pump.
  #3
Old 01-26-2010, 09:31 PM
well i took it to the dealer and they say it needs 1 new fuel injector and 2 oxygen sensors. so i decided to fix it myself since they want 3700 dollars! i will be changing all 6 injectors and all 4 oxygen sensors. that should solve the problems.........i hope total cost to do it myself approx 1000 dollars.
  #4
Old 01-28-2010, 08:06 PM
FavreOnSunday FavreOnSunday is offline
....get those O2 sensors off eBay... I did all 4 on my '01 for around $100... I say try that 1st, then injector... Is the Service light on?
  #5
Old 01-29-2010, 02:23 PM
i changed all 4 oxygen sensors, all 6 injectors, idle is smoother but has a p0505 code which is a idle air control valve. truck does not accelerate as fast as it should(something is wrong) had a new timing belt installed and rechecked the timing!..... it is good!!
  #6
Old 01-29-2010, 02:24 PM
yes service light is on, p0505. i will be taking the truck to the dealer now, tired of guessing what is the problem. pretty sure it is the iac valve but will need a volume relearn done with that as well. already put close to 4000 in repairs, so i got no choice to go ahead and replace the iac valve and let the dealer diagnose it correctly.
  #7
Old 02-02-2010, 07:55 PM
well i took it to a infinity dealer and they say they dont want to touch it because i have aftermarket fuel injectors and they cant diagnose it correctly because of that. wtf? i told them just replace the valve and do the idle relearn. they also cant explain or diagnose the misfire. is it possible maby a bad distributor causing multiple random misfire?
  #8
Old 02-02-2010, 07:57 PM
Angry
oh by the way, is anyone or has anyone had these symptoms. rough idle and hesitation when accelerating, anyone? hello out there, i cant possibly be the only one!
  #9
Old 02-03-2010, 02:49 PM
katielynns23 katielynns23 is offline
Hi Linus! I have an 01 QX4 with the same problem. It really scares me when I am sitting at a red light and my vehicle almost dies! After checking around on other forums it sounds like it might be the MAF sensor? I really don't know! I am taking my QX4 to my mechanic (not a dealer!) on Friday. Hopefully it works, I will let you know! Also let me know how yours turns out!
  #10
Old 02-08-2010, 10:26 PM
well i changed alot of parts, 4000 worth! same problems!
although i did need most parts, i am convinced the rough idle and p0300(multiple random misfire is due to carbon build up and sludge in the engine. i am currently running a cleaner through the engine and will run it through the intake as well. awaiting some auto-rx cleaner in the mail!. ill keep yoou posted. and by the way it is most likely that your maf sensor is good! if you cann accelerate good then dont change it, taht part is 140 dollars and can be cleaned with maf sensor cleaner!!!!!!
vB code is On
Powered by vBulletin® Version 3.6.10
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
infinitiforum.net recognizes that "Infiniti", "Nissan", it's logos and various model names and numbers are registered trademarks of Nissan Motor Co. Ltd.. These terms are used for identification purposes only. infinitiforum.net is not affiliated in any way with Nissan Motor Co. Ltd. or any other company listed herein. All information on this site is the opinion of its members and not the opinion of the site itself. ©2008 Madison Ross Media Group. All rights reserved. Content published on InfinitiForum.net requires permission for reprint.
custom floor mats | infiniti performance mufflers | infiniti performance exhaust systems | racing seats | infiniti euro tail lights | infiniti air intakes | infiniti projector headlights | infiniti ground effects | infiniti body kits, hoods and lambo doors | infiniti body kits | infiniti carbon fiber hoods | air suspension kits | air suspension parts
