strutmasters suspension  andys auto sport
Go Back   Infiniti Forum > Infiniti Forums (Infiniti Cars) > Infiniti J30 Forum
Register FAQ Members List Calendar Search Today's Posts Mark Forums Read
  #1
Old 11-30-2009, 09:05 AM
Aaron Aaron is offline
Default 1995 infiniti j30 headlights problem?
I notice my headlights seem to cut off and on. Mainly the passager side, wut could this be? I tried running lights in the day time while driving and they seem to stay on with no problem, but soon as night time come boom I start to look like a motorcycle coming down the road! So if I decide to try high beems I get nothing.. so if I deside to cut off lights and turn by on then no light but parkinging light will show. What could be goin on
__________________
Web Services by Yahoo!
  #2
Old 11-30-2009, 09:06 AM
White Chocolate White Chocolate is offline
Headlight relay Part# 25230-10Y60 MSRP $45.82
__________________
  #3
Old 12-08-2009, 02:27 PM
byrd43 byrd43 is offline
"Classic problem." This relay is located on the driver side firewall (underhood). It is pure H*ll to get out and even more to put back in. It does not look like your standard relay. You will see a black box and you're going to think that's not it but that will be it. You just unscrew the little screw and try and try until you get it out. I had to fashion a clothes hanger to hold both ends so that I push the relay back onto the connections.
  #4
Old 12-25-2009, 04:32 PM
janob05 janob05 is offline
i have a 93 j30t. had the same problem. even got as bad as no lights turning turning on at all... ever. popped the black plastic cover off the relay(when i finally got it out). re-soldered all the broken connections on the circuit board. works like a charm and saved 50 bucks
  #5
Old 01-04-2010, 11:31 PM
badbob badbob is offline
In order to simplify the removal & installation of the headlight relay you must remove the device next to it. To do this simply remove the 3 bolts holding the device which are accessed from the fender well. You need not remove the tire/wheel to do this.
vB code is On
Powered by vBulletin® Version 3.6.10
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
infinitiforum.net recognizes that "Infiniti", "Nissan", it's logos and various model names and numbers are registered trademarks of Nissan Motor Co. Ltd.. These terms are used for identification purposes only. infinitiforum.net is not affiliated in any way with Nissan Motor Co. Ltd. or any other company listed herein. All information on this site is the opinion of its members and not the opinion of the site itself. ©2008 Madison Ross Media Group. All rights reserved. Content published on InfinitiForum.net requires permission for reprint.
custom floor mats | infiniti performance mufflers | infiniti performance exhaust systems | racing seats | infiniti euro tail lights | infiniti air intakes | infiniti projector headlights | infiniti ground effects | infiniti body kits, hoods and lambo doors | infiniti body kits | infiniti carbon fiber hoods | air suspension kits | air suspension parts
