strutmasters suspension  andys auto sport
Go Back   Infiniti Forum > Infiniti Forums (Infiniti SUVs) > Infiniti QX4 Forum
Register FAQ Members List Calendar Search Today's Posts Mark Forums Read
  #1
Old 11-14-2009, 07:26 AM
ianmacdon ianmacdon is offline
Smile 1997 QX4 Intermittant stalling at idle
We have a 1997 QX4 with 200K on it, and it looks and drives like new. Lately ( for about 6 months ) it has been intermittantly stalling at red lights , or idle . I changed the wires plugs rotor and distributor cap. I also changed the air filter. Other than the stalling at idle, the truck works excellent. There are no error codes at all and the checkengine light is not on.
I am at my wits end, and my wife is getting concerned that sometimes it stalls going downhill and she may lose steering and brakes. The local mechanics have no idea . I am appealing to this forum for help that hopefully someone has seen this problem and knows exactly what it is.
Also, I cleaned the mass air flow sensor about a month ago using sensor cleaner, and the problem seemed to go away for about 3 weeks, then it came back, so i have no idea if the mass airflow sensor can be intermittant ?? Please, anyone, I need your comments. i will try anything.
Ian
  #2
Old 11-14-2009, 04:02 PM
Default Stalling at idle, and when driving going very slow
Today I removed the MAF again, and cleaned it with sensor cleaner. i must have sprayed half the can at it. I was confidant the truck would work good for a while, thinking it is an intermittant MAF, but now it works even worse and left my wife stranded in the parking lot , it now keeps stalling and is hard to start. I still have no idea ifthe MAF will cause all of this, and hate to spend a few hundred bucks for nothing., Has anyone ever had a bad maf ?
Thanks
  #3
Old 11-22-2009, 06:05 AM
Update : It appears no one reading my posts has had this wierd problem, so I will update you as I go along. Last Sunday, I had a wicked time getting the QX4 to start. Not to mention that I cranked it so much I killed the battery, and it was an old battery so it wouldn't recover , so I had to make a Wal-Mart run with the other car to get a new battery.
After I got that fixed, my neighbor came over to see what I was doing and I showed him the maf, and I disconnected the connector and re-installed it, and then the truck started perfectly.....
I now think that my problem is either a bad connector or an intermittant connection inside the maf.There are no error codes.
I ordered a maf on ebay for about 100 bucks, it should be arriving next week. When I simply swap it out, I will see if the problem disappears, that wll eliminate the actual connector as the problem, but if it re-occurs, i will further investivatge the wiring within the connector. In hindsight, I should really check the wiring first to eliminate the maf, but my experience in troubleshooting electronics makes me think the connector is fine , and the intermittant is within the MAF. When the truck is running normally, I can literally tap on the maf sensor with my nuckles and cause it to begin misfiring and stalling.
I will keep you all posted when I put the maf in.
  #4
Old 12-01-2009, 05:50 AM
Smile New MAF fixed the rpoblem
Well guys, I finally got the MAF which I bought on eBay, and I installed it last night. The QX4 works great ....but, because the problem was sooo intermittant I still didn't trust the maf so I decided to test it for a few days. Then I decided to take the old one to work, where I have access to many troubleshooting aids, as I am am Electronic Tech in the HealthCare field.
First I checked the resistance of the visible elements, and they were both perfect at 20 OHMS, then I decided to check the resistance of the pins on the connector, and I found them very odd...in the meg-ohm range, which I though was strange, and it was not constant.
I couldn't fathom there was anything other than 3 wires inside the sensor, so I put the sensor in the vice, crimped the case and the top popped off.
Inside the sensor there is a very complex circuit, covered in a silicone based moisture pervention semi-liquid.
I then took out the surgical microscope ( which I also have for troubleshooting ) and examined the PC board under high magnification, and low and behold, there it was, a broken wire, not much bigger than a human hair. It was literally laying on the tab, not connected, which explained the intermittant matter of the problem, and which also explained when I tapped on it with my nuckle, it seemed to work for a short time.
WOW. I was so amazed at finding this, I now know the problem is fixed and the SUV isn't going to stall anymore.
I really hope this information proves useful to others in the future.
Ian
  #5
Old 01-13-2010, 04:21 PM
I see no one commented on my stalling problem, so i guess that an intermittant mass airflow sensor on a 1997 QX4 is pretty rare. It was a bad solder joint inside the maf . Oh well, I really hope this information is useful to others anyway. Bye
vB code is On
Powered by vBulletin® Version 3.6.10
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
infinitiforum.net recognizes that "Infiniti", "Nissan", it's logos and various model names and numbers are registered trademarks of Nissan Motor Co. Ltd.. These terms are used for identification purposes only. infinitiforum.net is not affiliated in any way with Nissan Motor Co. Ltd. or any other company listed herein. All information on this site is the opinion of its members and not the opinion of the site itself. ©2008 Madison Ross Media Group. All rights reserved. Content published on InfinitiForum.net requires permission for reprint.
custom floor mats | infiniti performance mufflers | infiniti performance exhaust systems | racing seats | infiniti euro tail lights | infiniti air intakes | infiniti projector headlights | infiniti ground effects | infiniti body kits, hoods and lambo doors | infiniti body kits | infiniti carbon fiber hoods | air suspension kits | air suspension parts
