strutmasters suspension  andys auto sport
Go Back   Infiniti Forum > Infiniti Forums (Infiniti Cars) > Infiniti I30 Forum
Register FAQ Members List Calendar Search Today's Posts Mark Forums Read
  #1
Old 11-04-2009, 06:04 PM
porsche2k7 porsche2k7 is offline
Default I30 Service Schedule
Hi All,
I have 2001 Infinite I30 with 91000 miles on it. Ready for the major service. I called a mechanic today and he mentioned that it does not need major service until 105,000 miles and minor service should be good at 90,000 miles. Can anyone confirm if this is right with the infiniti's?
Another mechanic mentioned that at 90K the spark plugs needs to be replaced.
I believe the original spark plugs are platinum based and normally have life on 90K-120K miles. Should I replace them at 90K?
What are the things that are usually done at 90K service?
Thanks in advance
  #2
Old 12-30-2009, 02:44 PM
tOiNFINITIaNDbEYOND! tOiNFINITIaNDbEYOND! is offline
Pretty much at 90K you do the same service as you would at 60k and 30k... i.e. every 30k miles service.
Spark plugs are recommended to be changed at 105K service according to owner's manual.
  #3
Old 12-30-2009, 02:46 PM
At 60K the coolant is changed.. so I am assuming that the next coolant change should be at 120K range thereabouts. However since the car is obviously going to be older by the time it reaches 120K miles, you might want to change the coolant earlier. Like maybe around 110K miles. Hope this helps
  #4
Old 01-15-2010, 05:21 PM
bossbrakes bossbrakes is offline
Well Have you done the service..
vB code is On
Powered by vBulletin® Version 3.6.10
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
infinitiforum.net recognizes that "Infiniti", "Nissan", it's logos and various model names and numbers are registered trademarks of Nissan Motor Co. Ltd.. These terms are used for identification purposes only. infinitiforum.net is not affiliated in any way with Nissan Motor Co. Ltd. or any other company listed herein. All information on this site is the opinion of its members and not the opinion of the site itself. ©2008 Madison Ross Media Group. All rights reserved. Content published on InfinitiForum.net requires permission for reprint.
custom floor mats | infiniti performance mufflers | infiniti performance exhaust systems | racing seats | infiniti euro tail lights | infiniti air intakes | infiniti projector headlights | infiniti ground effects | infiniti body kits, hoods and lambo doors | infiniti body kits | infiniti carbon fiber hoods | air suspension kits | air suspension parts
